Tino SE 2004 Problems
Hi, I have had a 2004 Tino SE from new and it has recently exhibited the following faults:
1. Usually in warm/hot weather the audio fails to respond to console & steering column controls. Switching the ignition off and on again solves the problem, but sometimes just for a few minutes.
2. The immobiliser light has started coming on all the time. This started just before I replaced the battery in the key and continued afterwards.
3. The front 12V power socket has died (rear is OK). Which fuse should I check & where to find it?
4. The reversing camera stopped working last week. Should I suspect the camera or could all these problems be wiring problems behind the dashboard.
Any advice would be appreciated
Do you have the owners manual? if so have a look it will tell you where to locate the fuses.
My guess is driver's side under the dash should be a removable panel. I'm not familiar with the tino but alway's check your fuses first.
I can't find my owners manual, but it probably wouldn't identify whuch fuses protecte what circuits, so I'll just have to inspect them all. But thanks anyway Charley!
