Hey all ive dug the compressor out of the loft so i can respray my new bumpers, any tips on spraying with a gun, syphon type, not gravity fed.
So far on the bumpers ive sorted any laquar peel, by feathering the edges and smoothing it, then a full rub down with 600 grit wet n dry paper. Chemical key spray so the paint sticks better.
Any tips for actually spraying apart from keeping the gun parallel to the job?
the paint is fairly thin, as is the top coat so i think i should only need a splash of thinners if any at all.
Being metallic is there a nack for getting a good finish, spray in only one direction, not back and forth, that sort of thing?
and advice helpful, thanks.
Paul
Paul
