Uk gti engine/loom into vzr
No, I tried to Ga14 into a pulsar, gave up when started getting nats shit. Sold it, then bought it back as a msi logged racecar
Sent from my GT-I9505 using Tapatalk
Yeah it would be that whole nats malarkey that woud frighten me..not into electrics/loom one bit..
Out straight chunk was it a pain in the arse to do??
Yeah I think it's all fine temp revs and fuel ok anyway, 1 plug in the bay different and one under the dash different, used a gti maf and dizzy which I changed the steel bit that bolts on to the vzr one.
Yeah I think stivs gonna map it, be some yoke n1 cams and gspec gears gone in too
if you want to put in a daughter boarded ecu,why not use a n15 sss ecu (23710-1n960). put your nistune / nismotronic chip into that, and plug it straight in to your existing loom. only other thing you have to do is wire in a rpm activated vvl switch to your now un-powered vvl solenoids.
i know this works because heres been a ton of aussies put the ve ecu and loom into their ve transplanted n15 sss's.
