I never actually did this with my old Gti so i'm assuming you'd just wire them into the circuit. I used the inner as my fog.Would it be a hard job to wire the inner to the outers............im hopeless at wiring...
? Do you mean just disconnect them..........Yeah just take the wires back out.Can it be reversed if the lights where ever going to change.......?
No the actual loom is different but the plugs are the same. If you got the whole loom for the back of the VZ-R they might but it'd be easier to just wire the inners to the outers.Would they work fine, if i got the pulsar VZR connections, and swop them with the GTI ONES?
Cut one of the wires that lights the outer lights and extend each end into the tailgate and wire the 2 ends to the inner bulbs. Do this for each side.
Sorry to bring up an old thread
But if i get Vzr Lights.. and connect them up onto the Gti.. will they work. eg, lights on, indicators, reversing lights etc with no modification?
and when i put on my rear fog the two inners will light up like they do on a VZR?
