What amp???
i think the bay is your best bet, have a look about, see how much you wanna spend, and stick to makes your familier with.
Ok mate just to make sure im on the right lines i need an amp which is 500w rms at least and that would be 250w rms per channel
most ads should give you all the pwer options, just look for things like this 2x 200 watts at 4 ohms, 1x 400 watts at 2 ohms, this is just an example.
GTi said:
i recomend getting a vibe amp if poss mate very good quality & decent priced too
i was looking at them today but they are 1 channel and i have 2 subs or was i looking at the wrong one? it was a mono box 4
the one i'm using is dual channel but i've got it bridged to one to run my sub, think its 300 or 400w RMS can get the model number etc.. if you want as i've still got the box n' that
i've just had a look on the vibe website it was the wrong one that i was looking at its the blackbox 3 i need gona find out how much it is :D
D class mono blocks are single channel & for 1 output , buy 2 for 2 subs.
Or 1 2 channel Amp, bridge the outputs then its 1 output also
Course Watts & RMS aint everythin , quality comes in at some point.
To be honest , 2 500W subs & 1 Boston GT22 would probably end up sounding just as good
Im currently running 2 sony 12" DVC subs, I am using a 1600w monoblock to run both of them and have not had any problems.
The amp is really suited to doing this job and would recomend for running subs this is what you get. :D
