Hi folks, wondering what the best cam shafts and ecu to mod an n15 gti might be? Any other mods other than exhaust, manifold, and air filter?
Cheers Johni C.
Cheers Johni C.
Cheers Johni C.
Light weight flywheel, light pulleys, for bolt on cams jwt s3r's or Tomy poncams. Or look into cat cams. As for ecu, nistune is a tried and tested way to map the car or else some use dastek or similar piggyback systems
Horsham Developments is a dealer for Nistune I believe. Pretty solid company to use. They may be able to help you with the cams too.
My older turbo map from there has stood the test of time.I thought Horsham was one to avoid aswell? although i know a lot of people go there...
Still going strong
Hdev chip, based on nistune but not nistune
what about some mint second hand jwt s4's for $300gbp plus freight
is your ecu a 71y05? if yes fancy a nistune chip (you install it, tune it etc) for $170gbp freight inc?
you'd have to buy both. the cams are second hand. the chip would be new.
ok.cool.soz.S4's don't fit UK gtis , they're all roller rocker.
-phone-
