wierd clutch
hey all, im new to almera's as you may know. ive done a search, but no good :( i think i did member seeing it somewhere, now i can't find it.
sometimes when i de-press the clutch pedal it clicks. only when the pedal is coming up mind. i member reading its a quick fix.
if anyone can help, id mucho appreciate it. its not major n dont effect the drive, jus plays on my mind a wee bit.
thanx a mil – david
Its quite a common `problem` ie most cars do it. Nothing ever seems to break or snap!........i think the pedal bush can be changed and this helps.
as above, ive found spraying spray grease on it helps to stop the clicking
mine does it aswell, i just put some copper slip on it and seems to stop it for a while, although im not filled with confidence by it, makes me wonder if im going to be stranded somewhere one day with a snapped cable.lol.
Mine clicks and squeeks, has done it since Ive had the car, never had any issues though
its just a nylon bush that has cracked nothing to worry about, it cant fall out
