will they fit?
stufagti said:
i think s13 calipers are a single side piston design?
so they offer no benefit over gti brakes.
JClark said:
IIRC Mitsubishi FTO calipers fit with a larger disc.
Yes the twin-pot FTO calipers have the same bolt spacing and can be fitted with 280mm cliosport discs. A member on here has them fitted. It does require a bit of fiddling with spacers and possibly the enlarging of the bolt holes where the caliper attaches to the hub.
If the S13 calipers mount further out and allow larger discs then they will benefit you as braking torque is increased simply by moving the caliper out. Like on the P10, you can use the 280mm rear discs from later P11s and P11-144s. You need the caliper bracket from the same cars but you retain the P10 caliper as it bolts up to the bracket which moves it out to accommodate the larger discs.
Dunno if the S13 calipers fit the N15 though, just saying that because they are sliding calipers it doesn't mean there's no gain to be had ;)
I don't think the S13 caliper will fit the N15 as its 4x114.3 and also uses a 280mm disk but if the S13 caliper fits then you could use the clio sport disc (don't quote me as im guessing) my mate might have a set of S13 calipers if anyone wants a try
Yeah we changed the hub but not the knuckle where the caliper is bolted to. The only bit we swapped was the hub part that carries the bearings and studs.
We're currently putting NA 300ZX front discs and calipers to my brothers Micra!!!!
Ivan
Ivan
300zx calipers on a micra thats mad
so in that case your using the S14 disks as well then. I was getting my hopes up to put S14's/ R33 brakes on my car. Looks like my only hope is R32 2.5 None turbo calipers then
