you tried pouring hot water over everything?
DO NOT take this advice.
exactly right!
NEVER pour hot water over your windows, at most tepid water should be used!
i have always used water but only tap hot as its gaining its heat NEVER hot!
however if your fronts are only working on middle and fast then it is rather the relay or the stalk
more or likely be the stalk though!
Very cold + Very hot = Crack, but not the type i'm addicted to.
