Wiring Colour Codes?
Hello Almera World,
I'm trying to wire my stereo from a SRi into a GTi.
Are the wiring colours the same?
Does anyone have the colour codes - (if thats what they are called!?) that indicate which colour is what?
From Block(Black):
Wire Colour / Value
Red:Value?
Black:Value?
Orange:Value?
Blue:Value?
Yellow:Value?
Purple:Value?
Purple/Black:Value?
Dark-Grey:Value?
Dark-Grey/Black:Value?
Green:Value?
Green/Black:Value?
Grey:Value?
Grey/Black:Value?
Others:
Wire Colour / Value
Light-Purple/White:Reversing Cam from Stereo
Red/Green:Value?
Red/Black:Value?
Brown:Value?
Light-Blue:Value?
Black/Grey:Value?
Red/Grey:Value?
Pink:Value?
Pink/Black:Value?
Orange:Value?
Any help would be great.
k3y
From Block(Black):
Wire Colour / Value
Red:Value?
Black:Value?
Orange:Value?
Blue:Value?
Yellow:Value?
Purple:Value?
Purple/Black:Positive?
Dark-Grey:Value?
Dark-Grey/Black:Positive?
Green:Value?
Green/Black:Positive?
Grey:Value?
Others:
Wire Colour / Value
Red/Green:Value?
Red/Black:Value?
Brown:Value?
Light-Blue:Value?
Black/Grey:Value?
Red/Grey:Value?
Pink:Value?
Pink/Black:Value?
Orange:Value?
I'll have a go at this from the FSM.
Pink: Permanent Live
Blue: Ignition ON
Red/Green: Illumination
Orange: Rear Right hand speaker Positive
Black/Pink: Rear Right hand speaker Negative
Light Green: Rear Left hand speaker Positive
Black/Yellow: Rear Left hand speaker Negative
Brown: Front Right hand speaker and tweeter Positive
Black/Red: Front Right hand speaker and tweeter Negative
Blue: Front Left hand speaker and tweeter positive
Black/White: Front Left hand speaker and tweeter negative
It doesnt differentiate between models except for RHD and LHD so they should be the same.
Hope that helps!
Blue: Ignition ON
Hope that helps!
Thanks Hally! Probably get to try this sometime later this week.
Regards,
k3y
if your running amps etc, would defo recomend runing a live from the battery and a earth from the body as the standard wiring is a bit shit, turn the radio up loud and it will start to dim on standard wiring
Taking a delivery of a Yellow-Top Optima Battery 2moro, which I'll wire via a 3.0 Farad Cap: which should sort that. Then I'll make a start with the wiring up of the stereo wires and amp. Already received the 2000W Wiring Kit by Autoleads so I trust they are better than standard?!
Probably stick the power cap and the amp under the seats - hope its safe to drill under there. I was thinking of mounting behind the seat but thought that would just take up more boot space. The Sub is already massive 12" AudioBahn Immortal I'd expect I'll lose a third of the space. So pulling back some vital inches for the groceries - hehe :D
