wiring diagram needed
hello guys i,m after a wiring diagram for a s reg gti almera.reason i,m asking is that i have been given the task of wiring up a sr20 engine thats in a ford ka the loom is now in place and all that is left to do is work out which wires go into the drivers compartment apart from the big plug that goes onto the ecu.there are two multi plugs on the other end of the loom from the ecu ,one plug is 8 pin and has the following wires BLUE/RED , YELLOW , GREEN/WHITE , PURPLE/WHITE , YELLOW/RED , PINK/BLUE , RED/YELLOW , RED . the other plug is 6 pin with the following wires GREEN/ORANGE , BLACK/RED , BLACK/WHITE thick , BLACK and 2 empty slots.also which wires give the ecu its power and can i gt round the nats system . i do have the key and nats boxs but not certain if i have the wires that go form the ecu to the nats box .many thanks for any help on this matter :):confused:
Welcome, were you on before? i'm sure a grass tracker cam on asking for diagrams.
anyway, these any good to ya?
I've got the full service manual put it's massive and there is supplements for different phases so it's a bit of a bitch!
what color wire do i need
a up
again what i really need to know what wires and what color wires do i need into the passenger compartment to make the car run as you may have gathered its not been an easy project and the wiring is all thats holding this up cheers :):confused:
