Decided its time I stopped neglecting it and appreciated that it performs better than my GTR on country roads (I probably just cant drive the GTR but hey!)
So Im making it look even more standard and underrated intially, with either a full or partial respray in the future.
As a few people will know, I still have a fair number of things to fit to the engine but havent had the time until lately.
While its looking a complete state bodywise, Im going to dismantle the suspension, replace the bushes with standard or uprated items, clean up the rust and respray, and then put on the KYB AGX/Pi setup from my SRi.
Current spec on the engine is:
2.0 16v Highport Autech tuned to 175ps
Fidanza Flywheel
Unorthodox Racing underdrive pulley
Energy suspension front mount
To fit:
BTCC 94/95 season IES prepped head
Thermoblok spacers
Unorthodox Racing water pump pulley
First off I removed the side skirts:
Held on underneath by these
Started to prize the drivers side off
Rear was hard and not budging
Eventually removed
Heres why it wouldnt move, copious amounts of filler poured in to try and hold it on. Had to cut through it with a hacksaw blade. The front came off so easily as the two metal mounts that were glued to the inside of the skirt and attached to the two plugs, had vanished
The other side was easy and took about 3minutes to do
From the last pictures you can see im left with plastic plugs and a few holes where the plugs have gone. So these will need filled. And obviously that shocking mess on the drivers rear quarter will need a bit of work too.
Fidanza Flywheel
To fit:
Thermoblok spacers
Eventually removed
