Info from description I thought added a good insight without images:
REVIEW
The common mistake made when buying an Oil Catch Can is that people are fitting units that reduce the size of the breather tubes. For the professional aftermarket parts developer the mantra is to keep to the same design performance as the OEM manufacturer ... OR BETTER. By keeping to this set of guidelines, upgrading your vehicle with after-market parts will not compromise on safety or reliability. In this case on Positive Crankcase Ventilation (PCV) Systems keeping to the OEM manufacturer's design rules means having no less an outlet breather tube size than original. Oil catch cans inlets and outlets need to be of the same diameter as that of the OEM. There is a reason for this: The manufacturer is concerned with keeping the crankcase free of pressure build up. Cheap $40.00 oil catch cans from eBay etc with have tiny 10 -12mm inlets/outlets, or fittings acting as reducers, reduce the flow rates of the PCV System thus causing back-pressure in the crankcase. This build-up of pressure causes engine oil to weep from the crankcase seals etc as they were not made to hold pressure. Pound for pound, diesel engines have more blow-by past the rings than petrol engines and thus flow through the PVC System is higher. We certainly do not want to hold back any pressure here. I have found one type of Oil Catch Can that fits the bill and we have it in our line up of products.
These specially made Hi Performance ProVent® Style HP200 Oil Catch Can do an excellent job of filtering out the oil from the crankcase gasses that are re-entering the engine through the factory setup … and they do this WITHOUT restricting flow.
In this picture above you can see the very large inlet and outlet size. At 24mm OD the outlets are much bigger than any other oil catch can!
In my opinion, superior to any other style of Oil Catch Can for another reason, it has 2 relief valves. (most other types have none). One is situated on the inlet side to relieve high pressure, the other on the outlet side to relieve any low pressure. Again, this stops any pressure build up even if the filter becomes blocked from you not cleaning it. It’s a great engine safe guard! Keeping the oil out of the air intake will benefit in 2 ways Firstly, oil mist in the air intake entering into the combustion chamber will reduce the octane rating of the combustible fuel. Mainly in petrol engines, this leads to a symptom called "pre-ignition". Pre-ignition is one of the quickest ways to damage cylinder heads, piston crowns and piston rings. Secondly, (and the main reason) oil entering into the intake manifold combines with the heated gases of the Exhaust Gas Recirculation (EGR) (300-400 deg Cel) and literally bakes to form carbon build-up in the manifold. This carbon build-up, over a relatively short period, restricts the volume of air that would normally be allowed to flow through the manifold into the combustion chamber. (See pictures). The less flow, the less performance. This is well noted on late model Mitsubishi, Toyota and Nissan vehicles.
What your engine is breathing from the EGR System
The last picture shows a CLEANED intake manifold. (same manifold as shown above in the first 3 pics) If you could start with this and add the Oil Catch Can then this would be best. Blocking the EGR System is also advisable.
CLEANED PAJERO MANIFOLD
Looking at this pic above and comparing with the 3rd pic of the manifold it looks like No 4 cylinder was getting no air at all !! The modern diesel engine manufacturer’s idea of emission control that ruins your engine hoping that the problem occurs AFTER your warranty period has expired. They laugh all the way to the bank of course. The Chip Tuning HP200 Oil Catch Can has a replaceable element. Maintenance on these is easy too since no actual fittings or pipework is removed to replace / clean filter element. Fitment check list: Keep Oil Catch Can hoses away from turbo or hot exhaust manifolds as much as possible. If a hose travels close to a heat source, shield it. There are arrows on the side of the HP200 to advise direction of flow. The top inlet is connected to the rocker cover (ie VAPOUR IN). The bottom outlet is connected to the air intake. (VAPOUR OUT).
This totally sealed system makes the Oil Separator completely legal.
Chip Tuning HP200 Oil Separator Dimensions: 109mm width x 221mm height Bracket mounting hole centre to centre 122mm. Outlets 24mm OD or 25mm including swage.
The Kit comes complete with:
Filter Housing
Filter Element
Clip on Mounting Bracket
Hose Connection Heat Shrink (to save on expensive hose reducers / adaptors)
Oil Drain that can be capped off or returned to the sump
Totally legal to fit
Universal fitment
Sent from my iPhone® using
Tapatalk
