Curtis' GTI
This weekend im fitting my Lightened flywheel and a brand new clutch
Also changing a split driveshaft oil seal and some fresh gear oil :)
Hope the weather holds out :)
Pics on their way :D
Pictures i took when i was @ powerstation having the laser allginment done..
Can anyone guess what car this is?
Changed my flywheel to the lighter one :) like the picture from the back
Thats the prodrive P2 isnt it? Concept car type thing. Awesome.
Have you noticed the difference with the new setup?
Rota Grid Drift alloys in white 16x8 - Ordered :D
Lightened flywheel has made a bit of difference
New oil seal is on the drive shaft now so no more leaking gear oil
Flat beam wipers now fitted, much better than the standard ones!
To come:
Smaller de cat
Uprate front speakers
fix down sub + amp
Colour coding
Blow over
Weld on a plate to protect exhaust and sump (bit low now)
Bucket seats
will be close to the arches actually depending on how low you go.. my 17x7.5 with 225/45/17 with 20mm spacers taking them down to an ET of 15 caught the arches :(
Jealous :mad:. Don't think the N16 can take that offset, and I want sticky in angled spokes! :P
16x9 et15 = RIM out of arch front and back on the N15
Stretch a 225 tire though and its Tire tread in Arch - JUST.
16x8 et10 will be similar position in arch.. needs a stretched tire...
Will look epic though.. just expect some pulling.. if not stretching tires, or pulling arches.... then by the 50
xxx
