Dastek fitting and compatibility with sr20de question's
All it does is alter the signal that comes from the MAF into the ECU.
Maf in, maf out, RPM, live & earth is my guess.
I doubt it if its only 5 wires. Injectors need individual control so youd have around 10-12 wires with a MAP sensor too.
Greddy Emanage Blue/ultimate will do all that can (mostly) and you can do it yourself. @Spyke Liam and myself have all used that setup and had good results. It doesn't require a company/person to map it either. Just a laptop and the support tool.
Sent from my GT-I9300 using Tapatalk
It can do all of that. Airflow, Injector, Ignition & MAP. You can also feed a wideband AFR in for ease of mapping.
Interested depending on price mate,yeah i know about the Unichip Q is a lot newer and it can hold 4 different maps iirc.But i need to make sure it will work with this motor etc,ie not affect Nat's etc.One of the tuning place's for these are near by also where i live which would be handy.
