shaggy_master
brapp brapp!
My P11 GT Engine came with a manifold with no precats or anything in it..
and no its not an aftermarket one either.
Joe
Joe
P11 GT,s Do have a precat/resinator in the maniflod mate, my P11 SRi did and so does the P11 GT i have now.
Anybody explain how the GT has around 150 bhp whereas the N15 GTi only has around 140 bhp. I know all about the differences between the 130 bhp sri p11 engine and the GT version but unsure of the prim to almera differences, ta
iirc the De has less aggro cams, different ECU and maybe a couple of other bits and bobs, doesnt it also have a totally different intake? im sure it has the airbox on top of the throttle body like the GA's have
Surely that means a SR20De can be easily converted to an SR20DE?
yeh so in effect a GT and a GTi will have similar power if they had exactly the same mods
Tech1 I though DS engines were single point injection and the DE engines were multi point.
Ivan
SR20DE is the more powerful of the two engines between it and the SR20De, the gains are produced by a different set of cams, ecu set to rev out at a higher rpm, a sports catalyst and downpipe from manifold is a twin pipe design instead of a single. all this gives a gain of around 20 bhp over the De unit.
The DE is fitted to all GT and eGT versions and some SE versions of the primera. All other 2.0 primeras with the SR engine have the lower power version (De) including the Sri,s .
