Got this few weeks back. It was bought with a hesitation problem. I changed the Oil/Fuel Filter, Oil, Plugs, Leads, Induction kit, adjusted timing but problem is still there????
Will have a go adjusting the TPS tomorrow... if it still doesn't cure it then the im going to pull the engine out and Br...... :tt2: put another one in
Engine;
G-spec lightweight pulley's (crank and water pump).
Fidanza flywheel.
BMC CDA intake.
Fuel lab AFPR.
Kent NP2002 cams.
SFS silicon top and bottom radiator hoses.
Asp header.
3" mandrel bent exhaust.
uprated engine mounts.
VLSD gearbox with standard GTI ratios.
Short shifter.
ACT clutch cover with genuine nissan presure plate and release bearing.
Engine uses 300ml of oil evey 1000 miles. compression test shows 165PSI across all 4.
chassis
BC racing coilovers.
Whiteline rear anti roll bar.
goodridge brake hoses.
Fully superpro poly bushed.(rear beam, front arms, anti roll bar and steering rack).
Team dynamics pro race 2 with toyo tyres (fronts 5mm, rears 7mm).
Red stuff front pads.
Exterior.
Phase 2 GTI headlights and indicators.
VZR grill.
VZR rear lights.
![36603884.jpg](http://i613.photobucket.com/albums/tt220/omairsaleem/36603884.jpg)
![5276a3df.jpg](http://i613.photobucket.com/albums/tt220/omairsaleem/5276a3df.jpg)
![6e32df0d.jpg](http://i613.photobucket.com/albums/tt220/omairsaleem/6e32df0d.jpg)
![733dfe41.jpg](http://i613.photobucket.com/albums/tt220/omairsaleem/733dfe41.jpg)
![abe15d50.jpg](http://i613.photobucket.com/albums/tt220/omairsaleem/abe15d50.jpg)
![43d43f63.jpg](http://i613.photobucket.com/albums/tt220/omairsaleem/43d43f63.jpg)
![be3b9f13.jpg](http://i613.photobucket.com/albums/tt220/omairsaleem/be3b9f13.jpg)
![47a86bea.jpg](http://i613.photobucket.com/albums/tt220/omairsaleem/47a86bea.jpg)
Engine;
Fidanza flywheel.
BMC CDA intake.
Fuel lab AFPR.
Kent NP2002 cams.
Asp header.
Short shifter.
chassis
Exterior.
VZR grill.
VZR rear lights.
