Well Rob everything back there is the same. All you need to convert to them is the dials them selves and the two cables that operate mode and temp. Then remove the solonoides(sq?). You could also then remove all the extra sensors to them save weight lol.
Hopefully. Ive already got all the sensor and bits needed for electronic control so its a case matching the right wires to the right bits... in theory.
I wonder if this would work if it does that is going to be one of my next mods as I want to get rid of the screen. I am guessing there will be no trip computer
Well no, I will be getting rid of everything in that center consol (and I mean everything). So I'll be buying the Interceptor dual scan gauge which can monitor loads, and display 4 things at a time, e.g. mpg, oil temp, speed, rpm, etc, etc. But's that another topic...
...and yes, I wonder if it'll work too, as is the purpose of this thread.
