Thanks for your comments, when I said it wheel spins in 3rd I meant the wet... :hammer: DOh!
Yeah the mods: (not to many)
- Warbro 255 fuel pump
- RNN14 FMIC
- Techniclutch fast road clutch
- Blitz induction kit
- Bailys dump valve
- Powerflow custom full stainless exhaust (de-cat 2.5inch)
- Custom fitted engine loom (Fitted by Fusion Motorsport)
All the other things I had to do...
- Drill out Almera flywheel to bolt on to Pulsar block
- Used the Almera gearbox and drive shafts
- Used Almera air-con plus pipes
- Used Almera alternator plus Almera belt
- Back of the engine bay had to be heavly modifed to alow for the engine to twist on the mount. So the power steering pump wouldn't hit on the back of the engine bay
- When fitting driver side drive shaft could only use two of the mounting bolts for the support arm
- Used the Almera loom mostly, taking what was needed from the Pulsar loom (All work was done by Fusion Motorsprot)
- Using the Pulsar ECU
- Using the Alerma disie cap as the coil is biult in
- Battery tray needed moving and cutting a bit
- The lower engine mount bar needed to be modifed to clear the bottom of the engine
That pritty much covered everything I needed to do.
When I was out last night having a little drive about like you do. I came across an Astra VXR and I am happy to say I beat that with ease once the wheels stopped spinning. Then I had a bit more fun with a R33 Skyline... He come up behind me asking for it so I gave it everything I could! before I knew it I was pulling away from him... 1 car lengh... 2 car lenghs... 3 car lenghs... I was over the F**king moon
then I slowed down at the next roundabout and did the same thing again!
After this the smile on my face was from ear to ear! We pulled over and the man in the sklyline ran over to me saying "What the F**K is that? Why the F**K is it so FAST!!!??? I told him what I done and he was well inprested but I didn't beleive me and I asked why? He said the his skyline is running 434BHP!!! At this point I just started to laugh... I love my car so much!
The next thing on my list to do id to take the car up to Fusiong Motorsport to have a Nistune fitted to my car to have it re-mapped. I can't wait...
but the list does go on and on...
