minigibb_gti
What's my number?
is there any way i can get the almera lower than 40mm with out buying coilovers or cutting the springs ?
Yes they will, but because you are lowering and sacrificing travel with std length dampers you need STIFF sprigs to stop them bottoming out which in turn require STIFF damping which you won't haveDamo-Sri said:http://cgi.ebay.com/ebaymotors/91-9...015QQitemZ250088902796QQrdZ1QQsspagenameZWD2V
These ones? What the fuck are they, surely they wont fit or lower anything?
johnygti said:no mot if you chop the springs!
rowdy-GTi said:N15 suspension, especially at the rear has very limited travel. Lowering more than 40mm will f**k it up. Coilovers is the ONLY way.
does it, you must have fucked shocks or somethingjohnygti said:40 mil is low enough anyway, it sits over your rear tyre!
almeratastic said:Shame coilovers are so god damn stiff for road use :roll:
Is there a technical reason why someone doesn't do a coilover that is only say, twice the spring rate (with appropriate damping), rather than up to 3+ times std N15 springs ?
LOL - I can just picture the baby bouncing everywhere with projectile vomit all over - just like the scouts eating on the rollercoaster on Jim'll fix it :lol:markbuts3 said:My car is a little stiff for a 5 week old baby
Lol it's not that bad, in fact it sends him to sleep, but I cringe when I hit a big bump and keep looking at him to see how much it shakes him about.almeratastic said:LOL - I can just picture the baby bouncing everywhere with projectile vomit all over - just like the scouts eating on the rollercoaster on Jim'll fix it :lol:
rhyd4 said:does it, you must have fucked shocks or something
markbuts3 said:Because the dampers are already shortened then the travel isn't massive and too soft a spring rate would have you bottoming out or going coil bound with parallel wound springs.
Saying that, I do know that Dave ran 5/3.5 on his P10 in the US on his D2's and loved it. The std P10 eGT rates are 2kg/mm all round (the G20 has slightly softer rates) so not a massive increase. D2's std rates for the P10 are something like 10/5, I'm running 7/5.
I might try a set of 3.5kg/mm springs for the rear and move the 5's up front. My car is a little stiff for a 5 week old baby
That's the thing. D2 only recommend a change of 1 or 2kg/mm from the std rates that come with the coilovers. I assume that's because softer springs will allow bottoming out ???almeratastic said:If anything comes of this Mark, let me know as I may be interested. One thing though, will the dampers be in tollerance if the spring rates are changed by any significant amount ? Don't want to bugger them up.
