JDM Tyte Pulsar y0
my DE goes BWWWWAAAAAAAAAAARRRRPP
sweet tommo, if you need any bits for it give me a buzz,
youll have loads of fun in that!
even on std suspension, me and ed had so much fun with the lsd etc ;)
oooo go out and get some lsd gearbox oil, and refresh it!, :) inoticed that made mine a bit tighter :)
na not the dif, it the clutch, release bearing or main shaft bearing :)
the noise is coming from the front ish area of the box/block, so where the above 3 things all sit :)
Does'nt matter what oil you put in the gearbox it will not affect how the viscous works,they are a sealed unit that contains a silicon oil, do change the gearbox oil though as buy now it will have the texture of syrup and not doing a very good job of lubricating the Gears,bearings and shafts in the rest of it. you do not need to use anything flash (or friction modifiers) as you can make the gear changes worse by the fact the syncro's will not work properley (they need friction to work)
He could have been last year with the N16 too though Paul :p But he's with Jap N Crazy init.
