Kangerooing a bit more under control just being more gentle with the loud pedal ;-) , the chip is not a dodgy ebay resistor, its behind the dash somewhere, not sure what make it is will have to investigate
the ecu is on the transmission tunnel next to the bulkhead, if its connected to that then its a superchip and will be inside(so have to take the top off) of a greddy emange or a dastek will be more than likely velcroed underneath the ecu
although if its got one of the 2 latters it shouldnt be jerky really
I don't think its that jerky just when cold throttle response seems to be very sensitive, not sure what chip it is, will have to have a check at the weekend, guy said it didn't add any top end it just smoothed out the power through the full rev range....
