markbuts3 said:The supply voltage MUST be greater then the sum of the forward voltage of your leds in a series circuit..
So for 2v LEDs you can only run 6 from 12v. See my pic above, you need to run lots of parallel circuits with 6 in each.
Actually it's better to keep to a max of 80% of the total voltage, so 80% of say 14v is 11.2v. That means a max of 5 leds per series circuit...
Darren, I mentioned regulating the voltage earlier...
Oz. said:That looks really nice. I opted for LED bulbs as it's easier, and then discovered the bulb mounts in at an angle... :roll:
