Mega coolant leak from right under oil filter area (SR20DE)
I went about looking to fit intake thermal spacers.. it can be done but need to remove the belts then remove PAS unit then remove oil filter housing. All to undo the last impossible to get to last bolt holding the intake manifold in place! In the end decided to leave the job until take head off
Good luck..
Right so do i remove the pump from its bracket and then the bracket or can i just remove both in one go,i guess i just remove it but leave it connected to the banjo pipe ?
Also i could do with some more info on the oil filter housing,how many bolts,any seals behind it ect ?
I know this is not important LOL,but since the mani is off,should i clean it up and paint it ? Its not everyday that this thing gets removed !
Ok,i will order 2 seals from nissan,i am going to make another start with it now,wish me well,i am gunna need it will all that oil build up underthere :eek:
Ok today i removed the rest,oil cooler,lower mani,PAS pump,the problem hose was indeed the the water pump feed hose,had 3/4 spilt in it,and totally perish so all the hoses at the back of the intake manifold will be replace will gen Nissan.
Question is what are there part numbers ?
Ha ha,but the hoses are tiny,1 is about 3 inch,the other 2 are around 4 to 5 inch at most.Cant be to much LOL !
I just need the part numbers,i would of used nissan4u, for this info,but it dont work anymore :mad:
But normally they ask for part numbers right away,but i guess i have to anyway,deffo worth getting nissan hoses,i am not kidding to change the pipes is a mega PITA.
Well at the moment i am in the process of spraying the TB black, since i cant do anything till i get the hoses,i am also going to do the TB accel pulley gold,just to tidy it up really !
Might look good,might look shit,we will see tomoz when finish LOL
