cov_racer said:anybody got any clues why that engine uses 8 injectors, if its about shear fuel volume delivery, why didnt they shove huge injectors in?
Tech1_uk said:They use 2 injectors pre pot for more control on the fueling.
I run 8 440cc on my but at idle only 4 work as it would over fuel and flood up. Once reving around 4100 rpm to 8500 rpm all 8 are working.
If this had just 4 big injectors it would just bog down. Also the length of the trumpet on the trottle body matters as this changes the air flow in and the breathing of the air system.
Hally said:You really need to get some pics and specs of your car up instead of releasing little bits of information at a timeFrom what i've gathered so far, i know you're running throttle bodies, a dry sump setup and 8 injectors. Would love to know the full spec!
