Mov's Micra
Dude, please do me a favour (or a few to be exact)!
1. Put the stock rear plastic (black) bumper back on
2. Fit a much smaller exhaust tailpipe (something stock looking)
3. Buy a set of wheel trims and cable-tie them to the wheels to make it look stock!
THEN YOU WILL HAVE THEE BEST SLEEPER IN THE U.K. :)
lol the best sleeper in the U.K will be coming out soon!!!!
Micra K10
Thanks pal
Well i blew the radiator on Friday fixed that on Sunday.
Then i broke the outer cv (joys of boost)
Do you get the feeling something's against you bud :p haha seriously though unlucky .... are you still coming Sunday?
phone
  • Like
Reactions: Mov
Speedo is acting funny sometimes, the speedo/rev/temp/fuel counter goes up and down... which cause the engine speed to drop when the speedo has a mind of its own, only happens for split sec or two as soon i let of throttle its back to normal? it cant be the map cause it only happens on very few occasions and only when the speedo goes crazy does the engine hesitate!
Can it be the maf, speedo or speed sensor? or any other ideas
could be something to do with wiring between speedo and ecu? just thinking, my civic started playing up and it turned out to be that, could be worth a look as it wouldnt cost anything to check, sweet car by the way!
That was the exact reason why we used the Almera GTi hubs, so that we could use the CV's as well!
The Micra CV's are junk!
  • Like
Reactions: Mov
Would it not be better to use primera GT components, since N15 CVs and driveshafts are so hard to come by?
If it works, then id think it would be better to do so???
The only reason i think my micra failed was cause i lost all the grease due to a split CV boot, i reckon the micra one can handle around 300ish bhp/torque
gtir cv's are £20 each, they are the same as n14 1.6 sunny cv's.
the gtir use the same cv's front and rear.
cant you use fwd sunny hubs aswell?
Primera CV's are by far the biggest, but in saying that, I'm at 500 lbft and have never killed a GTi CV joint.
Driveshafts aren't an issue as there are companies in the U.K. that will make them out of Kryptonite if you should require some!
