okay done a tiny bit more work today got some of the engine stripped ready for taking out and removed the last of the interior wiring loom..
but im deciding whats the ebst corse of action for the new engine managment!!
this thing :-
might look like an ordinary distributer but it contains all the gubbins for sensing at what angle the crank and cams are at.. essential for setting up an ECU it uses a slotted disc with 360 slots in it and an optical sensor and some other black magic items.. but there are only a few stand alone engine managment systems that can read this signal. if i carnt find one that reads mine i will have to make a new pully for the car with a slotted disk and a new sensor..
but the plans for stage 1 are
Removel of engine and fitting of a new clutch
Removal of ABS and asosiated wiring harness and controll unit..
the removel of some small rust spots and the painting of the interior.
Make a new aluminium dash
remove the whole cars wiring loom
take the car to a specialist wiring place and have a full new cut down loom made to run the basics of the car
fit a new standa lone ECU and have it mapped
then ill have my car back minus a shed load of weight and the ability to fit and map a new engine which will be built over the course of next year..
