---------- Post added at 22:43 ---------- Previous post was at 22:42 ----------
then decided to move the gauges...
moving the gauges.. mock up
couldnt actually fit the other holder anywhere because of the angle and curve of dashboard
---------- Post added at 22:43 ---------- Previous post was at 22:43 ----------
This is the view from the drivers seat...
---------- Post added at 22:44 ---------- Previous post was at 22:43 ----------
they arn't even fixed in but they already have a good fit.. should look pretty good when all snug up.
---------- Post added at 22:44 ---------- Previous post was at 22:44 ----------
Crank is polished and refit.. .ALL NEW BEARINGS are in..
Mains, Rods and thrust bearings. And the cranks spins nice by hand. no tight spots and smooth,
Its a lot of work but seems to have made a very big improvement as you can see..
There is a couple before, and a couple after, and one during..
The middle bearing which had failed has had the biggest improvement..
Seems like a nice crank from What I can see now.
