My New Car...
nice maintenance and repairs. where can one purchase the new KYB part? my mate at work has the same issue. he also has 400ml of charge oil if you need some cheap.
dd
dd
I got it from a local motor factors but you can get em on eBay, they are just the same as any E12 corolla T-Sport.
Yeah if you could find out if he'd be willing to part with the oil and how much that'd be great as its a nightmare to get hold of.
I never knew superchargers used their own oil, i assumed they were fed like a turbo.
I like the car for the fact it's rare and quite a sleeper. Do they respond well to mods? Strong engine?
yeah in the case of the jap made Ogura charger on this it takes about 60cc of oil in the reservoir for the gears inside the casing.
Strong engine yeah, has its weaknesses like any engine, but overall it will rev to nearly 8500 daily without any drama', and is used in supercharged form in a lotus and is a common swap into MR2's.
As for mods the ECU is not mappable in any way due to the limited run of only 250, so it really only supports Intake / exhaust. headers are available but at nearly $1000 are very rare. there was a company down south that developed a smaller pulley kit for the compressor, but they went bust and the kit was near enough £2000, but came with mapping, FMIC kit and a fixed pulley, as opposed to the OEM clutched pulley. cams are available but not exciting profiles. I felt good gains on the butt dyno with the panel filter alone and I'm quite hopeful to see a good gain with the exhaust as it should allow the supercharger to breathe better due to the engine being able to pump out gases faster.
Things like lightened pulleys are a no-no as un-dampered crank pulleys have a tendency to grenade the oil pump on this engine.
If you really wanted to go balls out, you can buy turbo manifolds cheaply on eBay to take a T3 turbo.
Bit of nerd porn here about the development of the engine : http://2zzge.com/library/2zzge-engine.pdf
Last I heard Se7en motorsports were developing some decent cams.
Their Rotrex kits look decent but way too pricey imo.
New exhaust was built yesterday:
chopped the stock mid section just behind the cat and welded on a flange there, 2.5" pipe from the catback with mandrel bends.
welding up the completed mid section
fabricated the merge for the two backboxes
pipe between the two boxes
from the back
Finished rear section
Not stupid loud, but it certainly isn't quiet! makes some nice noises on lift now though!
