Hello there..
I want to introduce to you all my bog standard ph1 Almera GTi, being very careful not to step on Rowdys toe's. (pretty sure yours has adopted the name Trackmera anyway )
It's not going to be quite on the same level as Rowdys but the plan is to start getting into doing trackdays, and then hopefully when i get enough expieriance/confidence i want to race properly.
At first I wanted to import a VZR N1 for the task, but due to lack of funds and the fact they are so rare i've decided to go for a cheap as chips GTi. I will be keeping the engine pretty much standard i think just until i get a bit of experience and then i may try and go down the N1 route again.
I have been reading into suspension setups on sr20forum and cannot wait to get started on it. I've ordered some coilovers already and looking into getting all the bushes replaced, but so far its confused me quite a bit as there seems to be so many different ones. I'm not 100% sure which ones are worth change and which ones aren't.
Is there anything else anyone would recommend without spending silly money. Ideally i want to do the following.
Stronger sway bars
Uprated Bushes
Lower Bar
Rear strut brace
My first job is to find a wing and front bumper as the car has some light front damage, i've already replaced the indicator.
The interior is very clean and majority of it will be up for grabs if anyone is interested, also i have a good condition front right foglight if anyone needs one, aircon will be coming off so that available too.
Stronger sway bars
Uprated Bushes
Lower Bar
Rear strut brace
