N15 Track Car
So it has been a while, quite a few changes, pic heavy, not all in order.
Front brake cooling ducts
Bought a trailer, was too small
Exhaust was blowing along the seam on the back box, made a new one
Modified tha manifold so it didnt hang so low
Back to the exhaust
Slightly raised ally floor
Headlight duct
After this I went to anglesey. Trailed on the replacement trailer for the one that was too small. On the way home things didnt go well... tow car and trailer written off.
Bent up the rear beam on the N15 aswell
Replacement beam and link fitted and it was all straight and true, thankfully.
Replacement trailer aqquired too
Did another day at Combe once it was repaired. Real hot day with lengthy sessions, rear brakes were getting hot, so it was time for some cooling.
Whilst I was working the rear end I thought id do the panhard rod conversion.
Pulled the rear quarters and prepped ready for plastics4performance replacements
Also changed the rear springs for 7kg/mm. And have finally gussetted the cage to the B pillars. Hole saw will be making an appearance tomorrow to try and shed a few more grams.
Power
- Tomei Poncams
- XTD Lightweight Flywheel
- SoCal Tri-Y Manifold
- 2.5" LiamSpec Catback
- Walbro 190L/H Fuel Pump
- 3" LiamSpec ally intake pipe, Apexi filter, ally heatshield and fog and head light ducts
- Mishimoto Alloy Radiator
- Greddy Emanage
Chassis
- Quaife ATB Diff
- MeisterR Zeta-R 8/7 Coilovers
- LiamSpec Panhard Rod Conversion
- Full Polybush kit Front to Rear inc Engine Mounts
- Subframe Collars
- MR2 Twinpot Front Calipers with 305mm Discs and Carbotech XP10 Pads
- ABS Delete
- Braided Brake Lines
- Work Emotion 11R 17x8J Wheels
- Federal 595RSR - 235/40
- OMP Steering Wheel with 50mm spacer
- LiamSpec 4 Point Roll Cage
- Motomec GRP Seats
- STR 6 Point Harnesses
- GRP Bonnet with Aerocatches
- Lightened wiring looms
- Manual window conversion
- Hole sawed interior skins
Misc
- 2L Foam Extinguisher
- Dry Powder Extinguisher
- Oddessy light weight battery relocated to boot
- Front brake cooling ducts
- Plastic rear 1/4 windows with brake cooling ducts
Things on my list
- Front Roll centre correction ball joints
- 10kg/mm front springs
- MFactory 5.1FD
Got paid out by the other guys insurance. Was a 90 odd year old bloke, had a bleed on the brain and drifted into my lane.
