:lol::lol: thanks man!
Some info regarding the cluster swap.
It was a complete nightmare for me to make it happen..
I managed to make the cluster smoke two times trying to make it lit.
After the first time when I put back my stock cluster I didn't have tacho signal anymore...
The ecu tacho signal circuit was fried!
I've used this little device to fix my ecu tacho issue.
All it needed was to get signal from distributor or coil. I used the tacho output signal wire of my distributor. The adapter was set for low voltage tacho output using the dip switches and with the up/down buttons you calibrate the engine cylinders so that is accurate. The adapter produces signal also on the other output exits depending on dip switches settings. This could be useful to some who use several rpm calibrated devices.
Dakota Digital has some interesting adapters including for diesel engines.
I got another cluster to try on and gave it a new look.
I used these T5 SMD LEDS
The cluster had the stock plugs on!
Pin 13: 2 pulses signaling
This is the purple/red wire. This wire is used by the ecu to read speed. Without it ecu operates in safe mode and engine is in poor performance.
Most JDM clusters require this temperature sensor for the water gauge to operate
Plug 1 White: Pin 1 to pin 24 ( 6 pins, then 5 and 13 pins on the bottom)
Plug 2 Brown: Pin 25 to pin 44 (5 pins then 4 and 11 pins on the bottom)
Plug 3 Brown: Pin 45 to pin 68 (6 pins then 5 and 13 pins on the bottom)
This is what they look like
Pin 5: Seat Belt
Pin 7: Open door lamp
Pin 8: Open door lamp
Pin 9: Hand Brake (DRIVER SWITCH)
Pin 10: ABS
Pin 11: driver's door contact
Pin 15: SPEED IN.
Pin 16: Tachometer
Pin 17: FUEL LEVEL
Pin 18: WATER TEMP
Pin 19: rear window heating signal
Pin 22: driver's door switch
Pin 23: central lock window open signal
Pin 24: central lock window close signal
Pin 25: Left Turn
Pin 26: Beam light
Pin 27: Beam GROUND
Pin 28: SRS Ground (Airbag ground)
Pin 29: Right Turn
Pin 30: Hazard Switch - GROUND
Pin 32: 8 pulses signaling
Pin 36 : P indicator
Pin 37: R indicator
Pin 38: N indicator
Pin 39: D & 1,2,3,4,5,6 indicator
Pin 40: L indicator
Pin 41
Pin 43: KEY IN detector
Pin 45: Check engine
Pin 46: CVT
Pin 47: Glow light (not connected)
Pin 48: PTT light Probably not used!!!!
Pin 56: LOCK relay signal for passenger and rear doors
Pin 57: UNLOCK relay signal for passenger and rear doors
Pin 58 relay DEFROST WINDOW
Pin 59: GROUND
Pin 60: INDOOR CABIN LIGHTS
Pin 61: -
Pin 62: BAT (+)
Pin 64: BACK LIGHT
Pin 65: Back light GROUND
Pin 66: IGNITION
Pin 67: Oil Pressure switch
Pin 68: Charge battery indicator
I placed at Pin 63 the earth of the fuel tank sensor and solder along with pin 59 the earth of the speed sensor. I initially used the L indicator as the front fog lights indicator and then the P indicator. The ABS indicator was used for rear fog light.
Thankfully JB15 cluster had exactly the same wiring except the CVT indicators so I only have one fog indicator (abs light).
