does anybody know if these are the pin numbers for the STANDARD n16 clocks? or for the CVT clocks?
cheers guys and girls
Plug 1 White: Pin 1 to pin 24 ( 6 pins, then 5 and 13 pins on the bottom)
Plug 2 Brown: Pin 25 to pin 44 (5 pins then 4 and 11 pins on the bottom)
Plug 3 Brown: Pin 45 to pin 68 (6 pins then 5 and 13 pins on the bottom)
This is what they look like
Pin 5: Seat Belt
Pin 7: Open door lamp
Pin 8: Open door lamp
Pin 9: Hand Brake (DRIVER SWITCH)
Pin 10: ABS
Pin 11: driver's door contact
Pin 13: 2 pulses signaling
Pin 15: SPEED IN.
Pin 16: Tachometer
Pin 17: FUEL LEVEL
Pin 18: WATER TEMP
Pin 19: rear window heating signal
Pin 22: driver's door switch
Pin 23: central lock window open signal
Pin 24: central lock window close signal
Pin 25: Left Turn
Pin 26: Beam light
Pin 27: Beam GROUND
Pin 28: SRS Ground (Airbag ground)
Pin 29: Right Turn
Pin 30: Hazard Switch - GROUND
Pin 32: 8 pulses signaling
Pin 36 : P indicator
Pin 37: R indicator
Pin 38: N indicator
Pin 39: D & 1,2,3,4,5,6 indicator
Pin 40: L indicator
Pin 41
Pin 43: KEY IN detector
Pin 45: Check engine
Pin 46: CVT
Pin 47: Glow light (not connected)
Pin 48: PTT light Probably not used!!!!
Pin 56: LOCK relay signal for passenger and rear doors
Pin 57: UNLOCK relay signal for passenger and rear doors
Pin 58 relay DEFROST WINDOW
Pin 59: GROUND
Pin 60: INDOOR CABIN LIGHTS
Pin 61: -
Pin 62: BAT (+)
Pin 64: BACK LIGHT
Pin 65: Back light GROUND
Pin 66: IGNITION
Pin 67: Oil Pressure switch
Pin 68: Charge battery indicator
I placed at Pin 63 the earth of the fuel tank sensor and solder along with pin 59 the earth of the speed sensor. I initially used the L indicator as the front fog lights indicator and then the P indicator. The ABS indicator was used for rear fog light.
Thankfully JB15 cluster had exactly the same wiring except the CVT indicators so I only have one fog indicator (abs light).
