wont gain much than just higher fuel consumption! you do it by wiring up the solenoids at the ecu or in the engine bay, best bet is to have a look on the sr20forum, you'll get the info there.
The exhaust solenoid signal wire is purple and the intake one is pink with a black tracer.Find these wires down at your ecu,snip the exhaust wire about an inch from the ecu and join it up to the intake wire,thats it.
Well i can't say for sure as i don't have any RR printouts to back it up,the sr20v engine is a single activation so i think nissan realised its better,look it up on sr20forum for need to change fueling etc
