if it started life as a 1.4 then they have probably put the 1.6 gb on. so you will nee the 1.6 drive shaft AND WHEEL HUB. or u can change the box back to a 1.4 and get the 1.4 shaft and wont have to change the hub.
yes the shafts are differant and so are the hubs. you either need the full 1.6 setup or full 1.4 setup. thats up to u to decide. so its either a new hub or new box +driveshaft. either a scrappy or on here will be your best bet! however ebay is ok if your lucky. otherwise this wont be cheap. nissan wanted about 170 for one a while back.
where abouts in uk are you?
