Sr20de fuel pressure reading ?
What the pump you reckon,maybe its the reason i needed a AFPR in the first place !!!
Time for upgrade maybe....
You could do that but I'd swap the filter (for a Z32 one) and clean the MAF. Cheaper than just guessing at parts and if they aren't the problem and you end up changing the pump then you've set a good clean base for that for little outlay.
Logic.
Agree ^^ but i have tried to adjust the reg today,i can't seem to adjust it, according to the guage no movement at all in pressure,either i am doing it wrong or a faulty FPR,help !
Also when i pull the vacuum pipe off with the engine running,make no difference to the pressure !
Thats look very good for the price and proven,however mine was 30 quid lol,i expect a lot better.I wonder if its a fake also lol.
Lulz you paid £30 for it, its the same one as the one in the link both sytec. Fluid filled, nout wrong with the gauge quite commonly used
can you upload a video of the problem you having................
pull the fuel pump fuse and crack until engine cuts out, now all the pressure is removed from the fuel rail. does the gauge show zero?
refit the fuse and switch the ignition on, does the gauge move back up? if yes the gauge is working and the new fpr is defective.
  • Like
Reactions: CoV
