Had a full engine rebuild recently and this is the new list of mods:
SR20DE Engine Block
Oversized 87.5mm Forged Pistons
91mm Stroke TOMEI Full-counterweighted Crankshaft
Tomei SR20 N/A Conrods
12.7:1 Compression Ratio
Modified Block Skirts to suit crankshaft
Nismo Main & TOMEI Conrod Bearings
Enlarged Baffled Sump
ASL Chro-Moly Flywheel
Upgraded Exedy Clutch Assembly(using a triangular brass button clutch disc)
Billet Alloy Engine Pulleys - Anodised Blue
SR16VE N1 Specification Cylinder Head with modified spring seats to fit 'common' valve springs
Custom ground camshafts to suit engine, 304I/298E/13.2L/112LSA
Adjustable cam gears
NGK Iridium BKR7EIX Spark Plugs(1.3mm gap)
Top Gun 10mm Ignition Leads(no plug hole seal)
4x MSD Blaster Coil Packs
Bikirom daughterboard in an S14 ECU so I can run multiple ignition coils using a modified wiring harness. Also has flatshifting and VVL lockout when the temp gauge is out of range.
600Hp fuel pump
Tomei Quad-Throttle Body Kit adapted to suit VE head
Custom 4" Diameter Plenum adapted to enter the factory air-box
O2 Rush Replacement Panel Filter
3" Pipe from inner guard to factory airbox
Custom 4-2-1 Extractors
3" Metal Biscuit Catalytic Converter
3" Performance Free Flow Exhaust System
Walker Resonator + Rear muffler with dual 2.5" exit
ASL Garaiya 6 speed manual gearbox, with custom engine mounts and shift linkages
Nissan Maxima drivehsafts, ASL inner CV's, Pulsar outer CV's
Currently getting over 200Kw@the wheels, burning around 2 litres of 85% Ethanol fuel per minute at peak power.
Old ¼ Mile time: 13.24s @ 103mph with only 160Kw@wheels but aiming for a low 12 second pass or better when I can get it to the race track again. Only just completed a very long/exhaustive/expensive rebuild of the entire car.
