Soooooooo if fitted to yours the asp would make a touch more power, however the eBay header makes more than the asp. Why not go back to an 2.5’ eBay header then?...........
Because i now rev to 8200rpm, and the Fuji works great on a high reving, high compression engine. I would loose all my high-end, 'not dropping off' power.
Joe has perfected his driving style since using s3rs on the 1/4 mile. He probably uses different tyres, the car is lighter, oh and not forgetting the best mod for our cars, he has fitted a proper diff. I'd be doing 13.5s with that diff.
So its completely daft to say Joe ran 14s times with s3rs/ebay header and 13s with stock cams ASP header.
For the record i had shitty s3r cams at the aldon run.
imho a dyno graph without a recognised correction factor is worth nothing. Dot matrix also doesnt count.
