The engine was put on an engine dyno(engine out of car after rebuild) earlier this year(January,06) and dyno tuned before fitment to the car. It made 268Kw@crankshaft, which resulted in 201Kw@wheels originally and peak torque at this stage was 197FtLbs or 265Nm.
Some fine tuning resulted in the power graph I posted(about 205FtLbs, my Nm to FtLbs conversion skills might be a bit out). I later changed my intake to better suit my Tomei ITB's, with custom length ram tubes and got a reasonable power increase.
I was until recently using stock SR20DET conrods but cyl 3 rod failed(lateral buckle) so for the last few months, I have rebuilt the engine with new bearings, new pistons, Tomei conrods and new camshafts, etc. I will also be running the motor on 85% Ethanol, for more power, higher knock resistance + it is much cheaper than 98RON petrol
It is very reliable running that much power, with my only problem being a snapped driveshaft and the car squatting too hard on launches that it cracked the body panels above the rear strut towers.
I have pulled a 13.24 pass@103Mph(with only 160Kw@wheels) which had a crap 60Ft time. I did do another run that saw a 13.04 pass@101Mph with a excellent 60Ft time but I wont count that one, as the gearbox exploded just before the line and I rolled over the line
