Hello,
It's probably been discussed before many times and I have had a look to see if any other threads but I have a water leak coming in both sides of the boot, just below the rear lights and leaking between two panels. Someone has tried to use silicone before but obviously hasn't worked. I've water test from roof height and works my way down to eliminate any other seams. Water still crept in when spraying water just above the lights. I've removed to bumper to see if anything obvious but all seems to be well sealed still.
The only thing I can think of is either the boot seal or the rear light seals - a black tacky compound which I'm surprised is used by Nissan. If it is the rear lights, whats the best sealant to use?![431786667_409524385030776_3186378357637690171_n.jpg 431786667_409524385030776_3186378357637690171_n.jpg](https://www.almeraownersclub.com/data/attachments/11/11997-c996dfa225c51824a1588021bac9f835.jpg)
![429579364_1452913911969088_1770302002634499032_n.jpg 429579364_1452913911969088_1770302002634499032_n.jpg](https://www.almeraownersclub.com/data/attachments/11/11998-3a289e8b4b013c27fc09af595b1bfc36.jpg)
