Almera N16 Climate control unit not working, nothing showing on display.
Hello,
I have an issue with the climate/radio control unit, when I start the car, nothing is showing on display, fan cannot be controlled it does spin up and slowly going to full blast, the rear heated glass button work so do the CD player button, everything else does not. I have checked the connector, doesn't seem to be loose or burn.
Does anyone know what to do with this? What should I check/change first?
MAYBE, So I just followed all the FSM instructions on how to measure the wiring but there were nothing wrong with it, the problem solved when I unplugged the Calsonic Kansei Part number: ED01134710, wait a couple minute, and plugged in and everything seem to work again.
The control unit is located under glovebox for LHD. I think FSM have a instructions on how to remove it but it was held in if I remember correctly with 2 screws.
