Pfft, there is me thinking that this was an open budget build!
With a conventional arse end this would be in the the top 3 for me.
Like the way you welded the plenum to the adapter plate!
You should get the xcessive elbow to point the TB down, instead of straight out.
What master cylinder are you using? Have you retained the ABS?
very good... Like in my E92 BMW class 3... much better than OEMHow does the pedal feel?
You was faster here...so i see you used a ve maf in a 4inch intake pipe (like) what did you need to do to get it to work, tuning/fabrication wise?
