Little update
Well, after the major fail of trying to get it on with a rope yesterday, & another 2 fails today, I decided to lose the rope, & try summat abit different.
Having used various bits of wood to get the car high enough, I decided to use them again, to get the `box high enough. :lol:
As I wasn`t using the car ramps this time, I decided that they would be the perfect way of getting the `box to the desired height, by putting the `box on a length of wood, (in my case an old wooden mantlepiece) :lol: then cantilevering it over the ends of the ramps & then using the rest of the wood on the jack, to support the `box.
Now, all was going well, until it was time to mount the `box to the engine, where I discovered that it wouldn`t go on straight, so had to be rotated backwards slightly, so, using 2 slats from a shelf of the old airing cupboard, :lol: I was able to rotate the `box just enough for it to slide straight in at the bottom.
I put both the 14mm bolts in at the bottom 1st, to make sure it wouldn`t move any more than I wanted it to, then put the 2 17mm bolts in at the top & it closed up perfectly.
Only took these 3 pics because I texted Stu, so had the `phone in my hand.
Lining up the gearbox mount.
You can also see how I got the `box to where it needed to be. :lol:
engine brace with Solid front & Prothane rear mounts about to go on!
So it`s now back on the ground, :thumbs: just needing the clutch cable adjusting at the pedal, the intake & battery refitting & then, it should hopefully be able to move again!
