Rust treatment
Having found this thread again, & as the last update was just before JAE last year, it`s time for a little update.
Nothing much has happened since JAE really, apart from removing the resonance box from below the intake pipe & bunging the hole & totally removing the rear wiper, which has tidied up the back end a hell of alot.
The only significant thing to happen, is during the past month, I`ve been dealing with the spots of rust that have been appearing in various places around the car.
All is now sorted, & below are the pics of the process.
Noticed rust bubbling above the end of the skirt on the rear arches, so removed the skirts & set to work.
O/S rear arch
Sorted
N/S rear arch
Sorted
I then found rust bubbling above the skirts on both front wings, so removed them from the car to make the job easier.
O/S removed, good to see Kelvs underseal is still there & intact.
O/S wing
N/S removed
While I was at it, I decided to remove & tidy up all the supports in front of the rad.
By the time the paint had dried on the wing, it was getting dark, so I covered it in a tarpaulin, ready finish it off the next morning.
Looking very sorry for itself first thing Sunday morning.
After uncovering it, I set about the bottom cross beam
I also gave the horns a little tidy up, then put it all back together
Next job is to remove & tidy up the A.R.B, replace the drop links, fit the poly bushes & remove & tidy up the shocks.
![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
