Mov's Micra
what ever backbox you use make sure its 2.5" if its smaller then theres no point using it, you may aswell match the pipework to the box.
if the backbox is smaller than the piping before it, it will just be a restriction, Ive made this mistake before. There is no point using bigger pipework than the backbox.
if the spoon is 2.3 get 2.3 pipework
  • Like
Reactions: Mov
You'll be ok with that. If you're worried then just cut the inlet hole on the 'box to match the 2.5" pipework. Wouldn't worry about it to be honest.
  • Like
Reactions: Mov
Yeah thats what ill do as piping is the 2.36" and the tail is 2.55" so will do just fine
and cheers for the reply!
Like spook said, ill ask him phil if he can cut it if not then ill just get a 2.3"
Well thankfully everything is done...
Had to get the passenger side shaft shortened cause of the lsd
Had to make custom ARB brackets so it doesn't touch the shifter
Rear panhard and arb fitted
Also got the water pipe on the head custom made so i could mount the rad pipes properly.
Half under sealed
Had a go in it no problems at all :biggrin:
Will sort and tidy up all tomorrow hopefully
