Mov's Micra
But surely if you can turbo multiple cars and SR swap a micra, a simple cam change shouldn't be an job to be worried about?
Simple cam change trust me it's not... its still not running how it should be and i dont think i could have done better job than dale.
Cam in/out is the easy thing getting the timing correct is another issue which 2 weeks down the line still needs to be rectified
ohh btw turbo conversions and SR swap you dont need a lot of mechanical knowledge, as long as you know welding a bit of electrics its easy. For instance i can do a SR swap in few hours but id need ammar to change a clutch if i had to vice versa.
