Hi,
Thanks for the comments.
It has Daiyama Coilovers and its so low the downpipe scrapes on the floor.
The dashes and everything do work, as i have used the GTi wiring loom and just changed over all the sensors and dizzy etc, ive then got an emanage to get it running.
What would have been perfect is to use the GTiR wiring loom and then plug striaght into the the GTiR ECU and be running properlly straight away but like you mensioned the plug is alot different to the GTi one going into the dash and ignitition wiring. (dont fancy rewiring the whole thing)
But im having idling problems at the moment and a bogging under load. The emanage has not been correctly setup yet, im hoping the bogging is because of bad air/fuel mixture. As for the idling im stuggling at the moment, but im getting there slowly.
There are alot of little changes you have to do that doesn't make it an easy swap like alot of people say.
Jamie
