I'm afraid that in a case like this, you will need to get your thinking hat on for the electrics...
I can't really help you in that department as I don't touch the stuff...but if you can get you hands on the GTI and Primera eGT (same setup as GTiR) wiring diagrams, then you should be able to hotwire the buggers into each other like we did with my Micra.
But yes, if you are using the GTiR injectors, you should need to use the resistors.
Dave
Dave
