My Mera
No it does the opposite, it allows crankcase gases to escape and then is reburned via the intake. The PCV is one way valve, only allowing air out from the rocker cover.
If your pcv is bad, then air will pass in both directions resulting in positive pressure entering the crankcase.
Going to give the intercooler a light spray of black when I've got the bumper off next. The bumper needs more cutting still
Strangely enough mine are shot.
Under the plastic caps they were rusty as shit. Only found out when I'd had them cleaned etc then run up and ended up getting a bit stuck and jammed 2 injectors open so ripped them out :(
So I've got my loom available if you want it??
Sent from my SM-G900F using Tapatalk
What are you going to get next ? Yeah how much you after for it ?
I'm having some 370cc's flowed to 720cc's as they're cheaper than 555's.
Is yours phase 1 or 2 ( I presume phase 1?) as I may have to swap it over to the Phase 1 loom i have.
I have a feeling that I need some subaru plugs, anyone got spares?
Just make sure the fag that sends you them doesn't lie and claim they were just removed from his car...... then finding out they'd been sat in salt water for a fucking year..........
