Well i figured it was about time i started a thread for my gti having owned it for 3 years. I bought it as a bog standard non-bodykit version gti, the bodywork is pretty free from rust, just a couple of little bits underneath, the paintwork is shit and could do with a re-spray but i'm not too worried about that just now. Here's the current spec:
ENGINE:
2.5" pro speed custom mandrel cat back exhaust
2.5" de-cat pipe
Jperformance 4-2-1 header and 2.5" downpipe
JWT S3R camshafts
Custom alloy 76mm intake pipe
Jperformance oil catch can with PCV removed
BMC CDA carbon enclosed induction kit
4" cold air feed from fog light apeture
Nismo adjustable fuel pressure regulator with 52mm fuel pressure gauge
300zx fuel filter
Polyurethane front engine mount
Mobil super s semi synthetic 10w-40 engine oil
polished and slightly enlarged throttle body
Throttle body coolant lines re-routed
Thermoblok spacers (block to head gasket not fitted yet)
Pulsar gti-r silicone rad hoses
nismo radiator cap
Odyssey PC680 lightweight battery
NGK spark plugs
OE ht leads
17* timing advance
SUSPENSION + CHASSIS:
K-sport adjustable coilovers
B14 sentra alloy rear strut brace
Standard rear chassis brace
Whiteline adjustable rear sway bar
16" Rota circuit 8 lightweight wheels
205/45/16 Kuhmo ecsta ku31 tyres
lightweight D1 spec alloy wheel nuts
Energy Suspension lower arm bushes, anti roll bar bushes, drop link bushes, steering rack bushes
Custom steel solid shifter bracket
BRAKES:
Drilled and grooved discs
EBC red stuff pads
Dot 5.1 fluid
GTI-r brake stopper
INTERIOR:
Oil pressure, oil temp and water temp gauges in din holder
Autech interior
momo steering wheel
EXTERIOR:
non-bodykit version front splitter
Painted amber indicators
PH2 Gti headlights
VZR rear lights
VZR grill
JDM rear number plate surround
Aerocatch bonnet fasteners
wind deflectors
I've got a whole shed full of stuff to fit once i get some time free, including wilwood 310's, electric water pump, xtd clutch, p+p head and an abs removal kit on the way from kristian.
As she stands at the moment i've stripped 149kg out of the car, and i've still got vertially full interior! My aim is to get to 1000kg with full interior.
ENGINE:
2.5" de-cat pipe
JWT S3R camshafts
300zx fuel filter
nismo radiator cap
NGK spark plugs
OE ht leads
17* timing advance
BRAKES:
EBC red stuff pads
Dot 5.1 fluid
GTI-r brake stopper
INTERIOR:
Autech interior
momo steering wheel
EXTERIOR:
PH2 Gti headlights
VZR rear lights
VZR grill
wind deflectors
